58-60 JM - Engine paint - NCRS Discussion Boards
  • Loren L.
    • April 30, 1976
    • 4104
    My outdated JM reads in part "...therefore, aluminum intake manifold (because of poor fit of paint mask), and
    engine mount grounding straps may show slight orange overspray.".
    I'm not sure if I ever agreed with that portion about the grounding straps, but is the premise that the cylinder head area adjacent to the intake manifold/adaptor is orange still valid?
  • Mike E.
    • February 28, 1975
    • 5134
    Re: 58-60 JM - Engine paint
    No. The mask fit over the valve covers and intake. Poorly.
    • Loren L.
      • April 30, 1976
      • 4104
      So there is no "later information" that the area appeared in aluminum or silver paint?
      • Joe M.
        • April 30, 1990
        • 1338
        Speaking of the ground straps, I don't see why they would have been attached when the engine was painted. The engines were painted long before it was determined whether the car would be built with the radio option. It would stand to reason that if no radio, no ground straps. I think the only purpose of the ground straps mounted on the front of the engine was for the benefit of the radio. Correct me if this is wrong.
        • Dan H.
          • July 31, 1977
          • 1365
          Hi Loren, Joe, I dug out some of my Ice Age photos of a 2300 mile 59 and a 25K 58 FI untouched cars. Neither one shows any engine orange on the ground straps. The 59 shows silver paint on the thermostat stud threads, maybe this was part of paint shop work at Flint. The motor mount bolts, ground strap, and nut were all installed at St Louis and were not in place at Flint for painting. However, some cars have some paint on the ground stap etc in pictures, Dealer inhancement? Can't imagine the factory painting ground straps mounted loosely to the engine, would defeat the purpose of the ground!!! FWIW
          Dan
          1964 Red FI Coupe, DUNTOV '09
          • Joe M.
            • April 30, 1990
            • 1338
            I have seen a reddish orange paint mark across the motor mount bolt nut and a small amount on the end of the ground strap; probably indicating the nut had been torqued at St. Louis after the ground strap was installed.
            • Dan H.
              • July 31, 1977
              • 1365
              That could very well account for the traces seen. It's not 'overspray' and may have been random also.
              • Edward L.
                • 278
                The red/orange paint on the ground strap and nut was an inspection mark to indicate that the nuts had been tightened.
                As Mike stated in his post, the mask that was used covered the valve covers during the paint process. As such there would not be any paint in the valley between the valve cover and intake manifold. I have seen traces of overspray on the bottom front portion of the intake as well as small amounts on the bottom lip of the valve cover due to poor coverage of the mask.
                In this case a little common sense goes a long way. I think it's safe to say that the guys at Flint did not install the valve covers, run the engine, remove the covers to paint the motor, then re-install the valve covers.
