Solenoid door lock - NCRS Discussion Boards
Solenoid door lock
  • Lyndon S.
    • April 30, 1988
    • 1027
    Solenoid door lock
    Solenoid for door locks is this part still available for the C4 cars 1989 if so what is the part number for the parts.
    Re: Solenoid door lock
    Lyndon-----
    Yes, it is. GM #22062740 is what you need. The original part number was 22049686 which was recently replaced by the aforementioned.
    • David H.
      • June 30, 2001
      • 1485
      FWIW have you checked out the switch? Worth reading Mike Ingham's article in the Winter 2013 Restorer on a door window motor problem that turned out to be the switch.
