Dash Wiring on a 66 - NCRS Discussion Boards
Dash Wiring on a 66
  • Dan C.
    • February 28, 2011
    • 29
    Dash Wiring on a 66
    I am pulling out a custom stereo system for my 66 and installing an original speaker and radio. When I pulled out the glove box I found two pigtail wire connections folded over and stuffed behind.
    The first had a blue, white, and orange connection three way plug. The second wiring set had a orange, white, blue and brown connection. Anyone know where they are to go? I can't fathom that their was anything in that area to serve and their purpose.
    Thank you for any assistance.
    Dan
  • Dan C.
    • February 28, 2011
    • 29
    Re: Dash Wiring on a 66
    dash2.jpg Here is a picture of the area and pigtails
      Originally posted by Dan Chelko (53006)
      [ATTACH=CONFIG]44667[/ATTACH] Here is a picture of the area and pigtails
      Dan -
      Your car has air conditioning, and those two connectors are in the base dash harness for the heater resistor and heater control switch on a standard heater car; on an A/C car, those two connectors were taped back out of the way, as they weren't needed. See your Assembly Manual, section C60, sheet E8, item #2, tape.
      • Dan C.
        • February 28, 2011
        • 29
        John....thank you very much. I have the assmbly manual and did not see the reference. It is much appreciated.
