65 side exhaust - NCRS Discussion Boards
65 side exhaust
  • Bill W.
    • March 1, 1980
    • 2000
    65 side exhaust
    Too part question . I have heard stories about new or repro. side exhaust not sounding correct . I have started the restoration on my Rough 31.000 mile BB with side exhaust . My orig. pipes still have good chrome , the stainless part is very good and the header pipe is solid but rusty . I also have a new set I bought from G.M. in the 80,s Will they sound the same ? 2nd question I am thinking about taking my side pipes to redi strip along with my frame . Has anyone done that ? My concern is the baffling inside the pipe .
  • Larry M.
    • January 1, 1992
    • 2688
    Re: 65 side exhaust
    Bill:
    Your original sidepipes and the GM ones you purchased in the 1980's SHOULD sound the same......but your originals may be louder or more raspy due to age and wear.
    I WOULD NOT bring the originals to Redi-Strip, but would clean/refurbish by hand.
    I do not believe that GM sidepipes contained stainless steel. There is a carbon steel header section, aluminized steel chambered section, and chrome tips. That's all I know of.
    Both sets of GM pipes should have a "W" stamp, and GM part numbers on the pipes.
    Larry
    • Steven B.
      • June 30, 1982
      • 3976
      Re: 65 side exhaust
      Bill, I have used Redi-Strip for wheels, etc. and have been very pleased but I agree with Larry and would do the pipes by hand. Steve
      • Dale M.
        • December 27, 2007
        • 386
        Re: 65 side exhaust
        I just bead blasterd my side pipes. This did not eliminate the rough area on the header pipes close to the exhaust manifolds, but did provide a clean surface for me to refinished. Mine is a driver and my finish will not get past NCRS judging, but it pleases the car show type of people.
          Re: 65 side exhaust
          Bill -
          There is no baffling inside the pipes - just a core pipe with perforations in it, and the outer pipe that's crimped to create attenuation chambers.
