I'm considering installing a thermo blanket (Eastwood) against the floorpan before the new carpeting and would appreciate comments as whether the product is worth the expense and if it impacts judging. I still have the jute material from the original carpeting. Thanks...Clark
Heat/Noise Floorpan Wrap - Pros and Cons
Re: Heat/Noise Floorpan Wrap - Pros and Cons
Clark,
Several good articles in past Restorers magazines about floor insulation. The one I wrote in 2008 had heat test results in it. Best heat reduction material I found was http://www.hushmat.com/
Gary
NCRS Texas Chapter
https://www.ncrstexas.org/
https://www.facebook.com/profile.php?id=61565408483631- Top
Clark -
If you don't have the original issues, the NCRS Store sells DVD's that cover every issue ever printed. See page 130 in the current "Driveline".- Top
