Does anyone know where to get the ncrs correct upper and lower radiator hoses for a 1971 LT1? Thanks in advance. Phil
Radiator hose
Re: Radiator hose
Not exactly where, but this should help you determine what is "NCRS correct" (if there is such a thing). Based on this thread you ought to be able to sort out the correct upper hose for your 1971. Knowing that is a good part of the battle.
https://www.forums.ncrs.org/showthre...-radiator-hoseTerry- Top
Re: Radiator hose
Phil,
My 71 LT-1 had the original 3946852 with AU and a white stripe on it. I believe the TIM & JG says it should have JP AU on it.- Top
