Re: C5 Ice removal
We started using Propylene glycol in the 90,s due it lower environmental impact and low or no effect on animal life. It was heated to 250Deg F then sprayed on all aircraft surfaces to remove ice and snow. If there was still precipitation falling after the deicing procedure we would the apply a product know as type 4 ( first was type 2 then 3 each with a longer hold time) anti-icing it is like glycol but it has a thickening agent add to it called pseudoplastic making it cling to the surface it is applied to. Which should only be aerodynamic surfaces it add a hold over time before the plane would need to be deiced again due to snow or ice build up. On takeoff roll the aerodynamic wind shear would then cause the type 4 fluid to shear off the wing or any aerodynamic surface.
As far as your predicament if you had a large tent or canopy you could place it over the car and the introduce heat from a source to help it deice. For many years they were talking about using infrared heater to remove the snow from aircraft but never happened as of yet.
