I was planning on using POR 15 over the rust and cast blast paint on the differential since there is nothing wrong with it and the seals have been replaced.
Can a fully assembled differential be safely bead blasted? If so I may rethink and use Pre lube 6 to protect the bare casting. I will tape off the plated parts and use temporary bolts for the blasting.
Bill
Bill
At least I got my answer!
