Has this 54 frame been modified - NCRS Discussion Boards
  • Eric F.
    • June 30, 2003
    • 319
    I was recently looking at a 54 frame where the exhaust pipe passes through the right frame rail near the trans tunnel; it appears to me to have been cut away with a torch. It is painted black but I can't tell if it is factory paint. Was this modification done at the factory (which I doubt) or did a less than stellar exhaust mechanic find an easier was to "make things fit"?
  • Dan D.
    • November 5, 2008
    • 1323
    Re: Has this 54 frame been modified
    Definitely not factory.
    • Chris S.
      • January 1, 2000
      • 1064
      Not factory.....
      1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
      Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
      1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
      1957 Corvette - FI 3 sp - Black and Silver
      • Bruce B.
        • May 31, 1996
        • 2930
        I think the frame is original but it appears that someone cut some clearence at the top of the exhaust hole using a torch.
        In Noland Adams book "Corvette the American Legend #1" on page 31 there is a picture of a passenger car frame which was also used in Corvettes. Also see page 221.
        • Eric F.
          • June 30, 2003
          • 319
          Thanks to each of you for your input. It's unfortunate that someone actually thought it was a good idea to modify the frame to accommodate the exhaust pipe. Well, at least it can be fixed without too much trouble.
          • Eric F.
            • June 30, 2003
            • 319
            It's all fixed. Thanks again to each of you. Right Frame Rail Exhaust Opening - Repaired (md).jpg
            • Chris S.
              • January 1, 2000
              • 1064
              Looks good !!!!!!!!!!!!!!!!!!!!!
              • Bruce B.
                • May 31, 1996
                • 2930
                Very nice job.
