1969 Side Exhaust Valance Markings - NCRS Discussion Boards
  • Steve M.
    • January 1, 2006
    • 256
    I have a 69 350/350 that I am starting a body off restoration. In removing parts and documenting the parts with digital pictures, I came across the markings on the lower valence. The car has original side exhaust as per a call to the original owner from the POP. As you cam see from the attached picture this is the correct valence and has the correct part number. My question is, are the markings to indicate a side exhaust car? As I get further along, I am sure I will have more techinical questions but thought the marking might be of interest. Appreciate any comments.
    Steve
  • Mike M.
    • May 31, 1974
    • 8365
    Re: 1969 Side Exhaust Valance Markings
    i was involved in the resto of a 69 years ago that was an outsside exhaust car. there was a crayon marked "NO3" on the bulkhead right behind the drivers seat.mike
    • Michael D.
      • June 30, 1996
      • 536
      Looks like 73069 to me, possibly for July 30, 1969. Was your car on the assembly line on Wednesday, July 30th?
      • Bob J.
        Director Region VIII
        • July 31, 1982
        • 14
        My '69 side exhaust car has N14 in crayon on the bulkhead behind the passenger seat.
        • Mike M.
          • May 31, 1974
          • 8365
          bob: you are correct. my mind is heading south. it was N14, not NO3. mike
          • Rob M.
            NCRS IT Developer
            • January 1, 2004
            • 12695
            What is to find south for your mind, must be a US thing???
            Rob.
            NCRS Software Developer
            • Dick W.
              • 10483
              Rob, in the US, going South means going away, in his case he is losing what little mind he had left
              Dick Whittington
              • Mike F.
                • April 25, 2011
                • 668
                I have a 70 Coupe L-46, built May 18th, VIN 9516, line seq. 270. My lower valence has 3131 on it. No idea???
                • Rob M.
                  NCRS IT Developer
                  • January 1, 2004
                  • 12695
                  So it hasn't got to do with the most southern area's of the States (like Florida, New Mexico or Texas), like your brain gets cooked by the hot weather commonly encountered in those area's???
                  Rob.
                  • Dick W.
                    • 10483
                    Just a colloquial expression. We would use it in the Southern Hemisphere also. Now good ole Doc McCagh's brain has been fried for years, he has studied too many Corvettes
                    Dick Whittington
                    • Steve M.
                      • January 1, 2006
                      • 256
                      Thanks for the replies. Car is an October 10 1969 build. I have not gotten to the intrior removal yet but appreciate the 'heads up' about the markings on the bulk head behind the drivers seat. Thanks again.
                      Steve
                      • Paul O.
                        • August 31, 1990
                        • 1716
                        Steve
                        The bulkhead marking would be on the outside or underside of the body just in front of the gas tank. It could also be on the inside of the car but look on the outside first. Those on the outside or inside help the line worker know if a car had some special or different items being installed so the modification that were needed would be completed. Before body drop.
                        • Gary H.
                          • June 8, 2008
                          • 308
                          This was behind the drivers seat on my 69
                          • Mark D.
                            • June 30, 1988
                            • 2142
                            I would say every 69 I've seen, (with the carpet removed) that was originally equipped with side mounted exhausts, had 'N14' marked on the kick up behind the seat...just like Gary's picture.
                            Kramden
                            • Wayne W.
                              • April 30, 1982
                              • 3605
                              Almost every part had numbers marked on them. They appear to be simply accounting numbers at the manufacturer.
