Is a rear exhaust panel for a '63 different from the 64-67 ones ? - NCRS Discussion Boards
  • Ruud Z.
    • April 30, 2006
    • 69
    I am thinking of mounting a side exhaust system on my '63 convertible. One of the things that puzzle me is the fact that there is no rear exhaust panel avaible for a '63.
    I realize that this not an original option, but it was neither for '64 and the avaible aftermarket panels seem to be fitting a '64 as well.
    What is the difference and what options do I have (I want to keep my original exhaust panel intact in case I want to change it back to the original exhaust)
    Thanks, Ruud
  • Gene M.
    • April 1, 1985
    • 4232
    Re: Is a rear exhaust panel for a '63 different from the 64-67 ones ?
    The 66,67 rear valance panel is different from 63-65. The bezel openings have different features for the chrome/stainless bezels. The 66-67 chrome bezels are total different from the stainless bezels.
    • Michael G.
      • January 1, 1997
      • 1251
      Thanks, Ruud
      If your asking what rear exhaust panel for side exhaust will fit, believe any year will do the trick. The 1963 rear exhaust panel is a one year only panel.
      • William C.
        • May 31, 1975
        • 6037
        '63 had smaller outlet holes than '64-65.
        Bill Clupper #618
        • David L.
          • July 31, 1980
          • 3310
          The 1965-1967 w/side mtd. exh. rear lower filler panel is GM # 3863752 (wo/ bezel holes). I would assume that it would fit the 1963 with a side mtd. exh. but I have never attempted this conversion. The rear lower filler panel (GM # 3874799) on my 1966 is currently off the car (replacing exhaust system). If necessary, I could provide you with photos of it to compare with your 1963 panel.
          Dave
          • Michael B.
            • October 26, 2012
            • 28
            Believe the '63 has separate bonding strips on the ends for the flange that attaches it to the body. The later years have that flange built into the panel.
            • Michael G.
              • January 1, 1997
              • 1251
              Don't believe this provision would not keep a 64-67 panel from not fitting a 1963
              • Wayne W.
                • April 30, 1982
                • 3605
                It is different, but you can make it fit. 63 has no closed end like the later 64-67, and there is a small flange glued to make the mounting tab. Both of those things can be modified on the later units. Originally all of the rear panels were different, except the 66-67.
