Re: 1967 Headlights will not turn
Bushing is on other end, I was confused at first. I recommend taking the motor apart and cleaning the shaft and lubricating the bushings. With the gear stuck to the case that attaches to the shaft that turns the headlight bucket, you should be able to tap on the ean of the gear, but go slow and easy like the first one Great going. Dale
Someone with at lot more engineering and chemistry knowledge than I have will have to answer about the differences in the two.
