Protecto plate info for 1965-365hp - NCRS Discussion Boards
  • David K.
    • September 30, 1992
    • 281
    Hello to all; I received my Protecto-plate today with my 65'. The rear end info on the plate reads as follows: W0911AP. I'm told the car was produced on November 13th (Vin 2124). Could anyone please decode this info ? Thanks in advance. David
  • Henry J.
    • November 1, 1999
    • 457
    Re: Protecto plate info for 1965-365hp
    David:
    W=Warren, MI
    0911=September 11
    AP= 4-speed 327 Positraction, 4.11
    • Mike E.
      • June 24, 2012
      • 920
      David --
      The way I would read that is 4.11 gears,327, 4 speed & posi assembled in Warren Michigan on September 11th, 1964. The reason for the date spread is GM went on strike in September to early November. Your car might have sat on the line during the work stoppage or the differential was delivered to the plant prior to the strike and didn't get used until your car was built in November after.
      Mike
      • David K.
        • 281
        Thank you very much !
