1966/67 BB radiator support bracket question
Re: 1966/67 BB radiator support bracket question
My thick washers measure 1.370" OD x .175" thick, with an ID of .460" I'm not 100% sure they are original, but they do look the part of being 47 years old. The thinner washers measure 1.240" OD x .100" thick with an ID of .335"
BTW, the bolts measure 5/16" - 18 x 1-5/8" long with head marking of RSC with 7/8" thread length.- Top
Regarding the "thinner" washers, they appear to be the washer currently specified in the AIM; P/N 3688003 which specs out @ 1.25 OD X 11/32 ID X 3/32 thick and is long since been obsoleted per Joe.
If interested; Midwest makes a cad plated washer that has a slightly larger OD and is .116 thick, unfortunately the ID is much larger @ .43; however this will be covered nicely by the lock washer --- you will just have to keep it centered, or, find a thin wall washer/bushing to reduce it down closer to the bolt size. These are METRIC FENDER WASHERS and are carried by True Value Hardware. Note: I believe all True Value stores carry Midwest fasteners; however, not all of them will stock the metric fender washers. They are not perfect but 1000 times more accurate (and fuctional) than what you will find from the Corvette suppliers which only seem to carry very skinny reproductions around .062 thick which could allow the support to be easily crushed. ------ Best I could find so far !!!
Ralph- Top
Interesting thread - It appears the thin washer has part number 3688003 and know dimensions.
Knowing that GM production typically used what was available to fix a problem I don't think it is unreasonable to postulate that the thick washer existed some place in the factory so just used on the Corvette.
The thick washer used on various Harmonic Balance Bolts was pn 3864814 So if somebody has the dimensions for that pn it may turn out it was used as the thick washer everyone is seeing.
A little more support for this idea - the 78-80 Cadillac used this thick washer for the "radiator support mounting" Just a guess.- Top
[QUOTE=Alan Drake (43261);654252]Interesting thread - It appears the thin washer has part number 3688003 and know dimensions.
Alan,
Very well could be it, ID is a bit large but still works. looks like it's still available as well (see listing below).
Ralph
3864814 - WASHER
[QUOTE=Ralph Benedetti (49275);654300]I just realized the OD is too big @ 2.06", so may not be "thick" washer in question.Interesting thread - It appears the thin washer has part number 3688003 and know dimensions.
Alan,
Ralph
3864814 - WASHER
Kurt,My thick washers measure 1.370" OD x .175" thick, with an ID of .460" I'm not 100% sure they are original, but they do look the part of being 47 years old. The thinner washers measure 1.240" OD x .100" thick with an ID of .335"
Based on the assumption that the RSC head bolt you described is GM 454872 specified in AIM @ 1-5/8" long then the addition of the "thick" washer would be critical "or" the bolt would hit/damage the radiator, however, not an issue on the (2) center bolts that secure the shroud where we only see the single "thinner" washer 3688003 and lock washer 103320 used which complies with the AIM. ------- If this is the case then the AIM call out would be incorrect and the factory adjusted for the error by simply adding the "thick" washers in the (4) locations?
Ralph- Top
