I just recieved my new exhaust from Corvette Central (N11 with carbon steel pipes). The rule of thumb is go slow to go fast. This is the go slow part. I'd rather be on my back putting them on.
Be assured, this is not about bashing CC. They may be great and a great supporter of NCRS, but I want to be sure before I go forward.
As background:I considered Allen and CC and used CC because of posts that said they had less fit isses.
Secondly, this car once had sidepipes and where the system on it came from I don't know but I "think" it is potentially an original exhaust system. Your responses may shed light on this. So here are my questions and issues:
1. See picture below - StraightSect. The tailpipes I took off are formed to create somewhat of a retangular shape with two lines of tooling marks on the top and bottom. I think this is very much original. The pipes from CC have only one tooling line and are very oval in shape in the straight sections. Is this as good as I'm going to get? Is it more correct than what I have?
2.When you match the mufflers up the left system is longer than the old one (see picture LeftLength2), and the old left one is similar to the right. The new right side if fairly close in length to the old one. Maybe I can make this up in the joint adjustment and the rear hanger, but does this look like a serious issue to you? I'm thinking it is.
3. The tailpipe extensions rear of the muffler on both sides are about 5.25 inches whereas the old ones are 4.5 inches ( this may be manageable). The old ones have no visible weld (welded inside). The new ones have a pipe welded inside a nipple (see picture DetailRtRr). Which is more correct, the old or the new? Can I do better with a different vendor? Both of my old ones have the pipe welded to an extension on the forward end of the muffler similar to what CC supplied, although their extensions are much longer than what I have. How were tailpipes and rear extension welded to the mufflers (e.g., is the old or the new in the picture correct)?
4. It may be hard to see in the picture (ExhAngle), bu the new ones slant up to the fender more than the old ones. This gets back to the question: do the old ones look correct? What do you think and can/should I do better?
Any help or comment on this would be appreciated.
