AIM databases
Re: AIM databases
Don, This may be twice but could I get the AIM for 66 and agree to never sell or redistribute it in any way.
welshroofing@Verizon.net Thanks Greg- Top
Re: AIM databases
Donald,
I agree to never sell, or redistribute the AIM database(s) in any way. May I have databases for 1963, 1968 and 1974 please? E-mail: hugh9222@gmail/.com
Thank you,
Hugh Gregan
60832- Top
The light at the end of the tunnel has been turned off.- Top
Re: AIM databases
Don,
Can I please have databases for 1967 and 1972.
I agree to never sell, or re-distribribute the AIM databases.
Thank you,
Ron
r_egan@yahoo.com- Top
Re: AIM databases
Don,
Thank you,
Ron
r_egan@yahoo.com
Check your e-mail.
Don
Anyone else?The light at the end of the tunnel has been turned off.- Top
Re: AIM databases
Don, When attempting to download your files I'm using Access 2003. I'm getting the following error 'The database that you are trying to open or convert is currently in use or you don't have permission to open it exclusively.' Do you know of a simple fix?? I'm computer challenged but your database interests me alot. Thanks in advance whether you can advise me or not. Hugh- Top
Re: AIM databases
Hugh,Don, When attempting to download your files I'm using Access 2003. I'm getting the following error 'The database that you are trying to open or convert is currently in use or you don't have permission to open it exclusively.' Do you know of a simple fix?? I'm computer challenged but your database interests me alot. Thanks in advance whether you can advise me or not. Hugh
I have no idea if this will work or not......
try downloading the file,
then do a File Save As and add a letter or number to the name
try opening it in Access
I'm no software expert by any stretch of imagination and I didn't stay at a Holiday Inn Express
DonThe light at the end of the tunnel has been turned off.- Top
Re: AIM databases
There is a setting in Access that contols how it opens up a database and one of the choices is to open it up Exclusively. Your setting could be set to open exclusively by default and that needs to be changed. If you turn that off by un-checking the box it should work. It's been awhile since i've used that older version of Access but if you click on help with the program which might be a the question mark symbol in the upper right corner, then type in Exclusive, It should show you how to make the change.
you can also do a google searh for MS ACCESS 2003 OPEN EXCLUSIVE and there will lots of instructions.
Tom67 427/400 Lynndale Blue Corvette https://online.flippingbook.com/view/750924569- Top
Re: AIM databases
Please send 1962
Thank you for all the effort you have put into this project.
sampanjohn@earthlink.net
John Tidwell- Top
Re: AIM databases
Hi Don,
can an I get the database for '62 please?
I also agree to not sell, publish, distribute or charge any fees for use if this.
thanks so much,
Eric Eade
eeade60@gmail.com- Top
Re: AIM databases
Don
Looking to have a copy of the AIM 1968 to 1972 if possible.
oslansky@fuse.net- Top
Re: AIM databases
Don
oslansky@fuse.net
Paul,
There is not a compilation of the C3s like I did for the C2s. So if you'd like a shark database please select one or two, unless you want all 6 of the sharks that are available.
