C2 (64) Two More Exhaust Questions - NCRS Discussion Boards
  • Larry M.
    • January 1, 2002
    • 535
    1. The cast rings that hold the exhaust pipe up to the manifold on a 327, the ones I took off have a P C stamped into them. Does this signal anything? Original?
    2. I have tall brass nuts on my studs. I'm guessing this is not correct, right?
    • 6940
    Re: C2 (64) Two More Exhaust Questions
    Larry, the nuts that hold up the flanges to manifolds are stove nuts they are reproduced correctly, I believe that corvette central sells the correct nuts.
      Larry -
      Those are "stover" nuts (prevailing-torque self-locking nuts); Paragon has them too.
        • 6940
        John thanks for the correction. I missed the letter R
