1968 quadrajet - NCRS Discussion Boards
1968 quadrajet
  • Brandon T.
    • October 23, 2008
    • 872
    Re: 1968 quadrajet
    I'm going to install freeze plugs also. I was told they are 7/16 plugs. Advance auto told me they have them in stock. Is 7/16 the right size?
    • Russ S.
      • April 6, 2010
      • 134
      Re: 1968 quadrajet
      I used Sparky http://www.sparkyscarbs.com/ for my 68 quadrajet. Great to guy to work with.
      • Thomas H.
        • August 31, 2005
        • 1053
        #18
        Re: 1968 quadrajet
        Brandon,
        Normally I do all of my own work, including carbs. The original carb on my 71 LS5 had a stripped fuel inlet that I wanted repaired correctly. I used Custom Rebuil Carbs in NJ. I had them fix the fuel inlet and rebuild the carb while it was there. When I got the carb back on the car, after a very minor mixture adjustment, the car ran great. I was very pleased with the wrok they did as well as the cost.
        My 0.02.
        Tom
        2007 Z06, Lemans Blue
          • 15573
          #19
          Re: 1968 quadrajet
          My favorite is:
          Jim McGowan Quad Shop 5963 Lenden Rd. Rockford, IL. 61109-3516 815-874-4884
          • Joseph K.
            • August 26, 2008
            • 407
            #20
            Re: 1968 quadrajet
            It is a year or so ago since I did it. 7/16 sounds about right. The are cheep if you get the wrong size.
