OK, I have run across a couple of 1956 engine pads that seem to contradict the 5 - 1 - 1 - 5 (or 4 for passenger cars) engine stamping sequence.
Please take a look that these two early 56 engine pads. Focus on the sequence number, not the engine suffix.
Both blocks are 991 castings. The "GR" block has a casting date of K 17 5; the "GB" block has a casting date of L 8 5.
Regarding the "GR" block, with sequence number "0027972", the sequence APPEARS to be:
- 3 digits stamped together - "002"
- 2 digits stamped together - "79"
- 1 digit stamped individually - "7'
- 1 digit stamped individually - "2"
If this is correct, the the stamping sequence for this engine would be 3-2-1-1 for the sequence number. Note that this is a Flint engine.
Regarding the "GB" block, with sequence number "0076892" the sequence APPEARS to be:
- 3 digits stamped together - "007"
- 1 digit stamped individually - "6"
- 2 digits stamped together - "89"
In this case, the stamping sequence for this engine would be 3-1-2-1 for the sequence number. Noth that this is a Tonowanda engine.
I also find it interesting that this situation seems to be true for early 56 engines only. After some time, the 5-1-1 engine sequence number stamping appears to be true.
I have a number of examples wiere this is the case. Possibly those engines that had two or more leading zeros in the seven digit engine code (early 56 engines) were like this.
Pay no attention to the suffix codes, as the GR is definitely an altered stamp (R added), and the GB may be an altered stamp (B added).
