1989 headlights - NCRS Discussion Boards
1989 headlights
  • Lyndon S.
    • April 30, 1988
    • 1027
    1989 headlights
    for 89 who made the headlight bulb?
  • Jeff P.
    • July 23, 2010
    • 29
    Re: 1989 headlights
    I am pretty certain it is WAGNER
    • Ed N.
      • May 16, 2010
      • 990
      Re: 1989 headlights
      Ed Nieves
      NCRS #51799
      • Ed N.
        • May 16, 2010
        • 990
        Re: 1989 headlights
        Dave you are right, my mistake. Thanks for the correction. I never claim to have any mastery (as you put it), just trying to help.
        Ed Nieves
        NCRS #51799
        • Lyndon S.
          • April 30, 1988
          • 1027
          Re: 1989 headlights
          what is the part number for NOS headlights with the word guide in them?
            Re: 1989 headlights
            Lyndon-------
            Unfortunately, the GM part number is the same regardless of the manufacturer. Every 1984-96 Corvette (except export cars) used sealed beam GM #5972698. So, the part number cannot be used to identify a particular manufacturer. Depending upon when the particular sealed beam went into GMSPO inventory generally determines what the manufacturer will be.
            By the way, my original owner 1992 LT1 was originally delivered with Guide brand sealed beams and I would not be surprised if 1989 did, too. I believe that Guide was either still a GM Division at that time or had been spun off but remained a major supplier to GM. Many high-volume lighting products were manufactured by Guide.
            • James W.
              • December 1, 1986
              • 278
              Re: 1989 headlights
              Actually, my 90 ZR-1came with plastic Wagners. Best!!
              jim
              • Ed N.
                • May 16, 2010
                • 990
                Re: 1989 headlights
                jim
                James, that's interesting. Are you the original owner?
                Ed Nieves
                NCRS #51799
                • James W.
                  • December 1, 1986
                  • 278
                  Re: 1989 headlights
                  No, not original owner, but it was a 12,000 mile car when I bought it. Also, check the JM and it also states they shold be plastic on a ZR-1 only
                  Jim
                    Re: 1989 headlights
                    Jim
                    Jim------
                    Does anyone have a build sheet for a ZR1 and L98 or LT1 for any given model year? I'd be curious if the broadcast code for the headlamp assemblies was different.
