there were three design 56 power top harnesses.The first design had a TWO terminal deck lid safety switch and the trunk lid safety switches were located on the driver side . The second design harness had a FOUR terminal deck lid safety switch and the trunk lid safety switches were located on the drivers side. The third design harness had a FOUR terminal deck lid safety switch and the trunk lid safety switches were relocated to the pass side. Does anyone have the wiring diagram for the 2nd design harness, assuming its different than the third design. also could use a picture of the power top limit switches located on pass side atop the fuel tank cover. especially need to see the cable that attaches to the toggle switch and the bow assembly. thanks much,mike
56 power top
Re: 56 power top
hey guys, forget the above request. after 2 weeks of screwing with the power top assembly, i finally figured it out. it works slick as snot. thanks for all your help. if it were a little later in the day, i'd celebrate with a couple beasts. mike- Top
Re: 56 power top
It's 5 o'clock somewhere!!!
- Top
Re: 56 power top
Par topz will make you do that, but I wouldn't call it celebratin'.
- Top
