Many of you have followed my travels in the US and Europe over the last 3 years. Last spring I had to replace the windshield that was hit by a stone near Park City UT.
It was the 3rd windshield since car was new. I replaced original in 1976, could not see through (150,000 miles) on car, it lasted until 2012, about 150,000 miles.
In my rush to get the car ready for the European trip, we put the windshield in and followed right away with the trim. In hindsight, not a good idea. Lots of sealer and glue and junk, you are in a hurry and the job did not come out looking good. No leaks , but I was ruff with taking it off, put some bends in it, did not get the front piece centered, etc.
Well I got inspired by 65Rush (Jim) replacement and polish job on his trim.
I called over a friend and in less then an hour we had it off. The biggest mistake I made , and maybe others that have problems putting trim on , is too much sealer when installing windshield. Over concern with sealing everything. (too much around clips) etc.
Taking off trim is not hard, just have to do it in the right order. Take out every screw first that hold trim, latches, mirror etc. Trim screws, do not have to take off trim in front of pad.
Take off inside piece first (mirror) part, next top piece after gently pulling side pieces away from cage. (4 5/16 speed nuts 2 reg nuts hold trim) You must take of side pillar rubber first and mounting plate for trim.
You can then side out side pieces from front trim, next release the front trim with tool
I will post tomorrow a few pictures of the tool in action. Most have problems because they do not understand how the tool works to release trim.
Installation , have to wait until trim is done but....before putting trim on. I will talk about a order of installation later.
It is important to make sure the clips are free of sealer so they can grab the trim around the front windshield. Also , I found the grove of the front trim to be clogged with gunk, gunk in the grove, keep the clip from locking in place.
I am debating doing the polish myself, but don't feel good about it.
I hope this helps some of the new members who may be thinking of doing this job
Jack
Pictures
Trim off ready for repair and polish
Birdcage too much sealer
Before defects
Jack
Pictures
Before defects
