In regards to serial numbers on the engine stamp pad and on transmissions - were these done at the same time on the assembly line??? Thanks in advance.
Serial number question
Re: Serial number question
Blair,
The short answer is yes. The answer to your question is in a thread in the archives. I recall the discussion and statement by someone of knowledge on this. I tried to find the thread but it's buried by another name. You might want to perfrom a search and try to find it.
Paul- Top
Thanks gentlemen, for your reply - that was the answer I was looking for. Just noticed that the s/n on the engine stamp pad and on my TH400 looked identical (same font). One of the digits in the s/n on both the engine & tranny have the top part of the "4" (slightly faint) being the same. Hence the question - were they stamped on the same day?. With the consistency of both s/n stampings - looks like they were done @ the same time. Appreciate your insight. Regards BK- Top
Both engine and transmission stamps occurred at the same time and at the same station on the St Louis engine dress line. The engine/transmission assembly was hanging on a hook on the engine conveyor, headed for the chassis.- Top
Thanks, Michael for the attached pics - much appreciated.- Top
Correct me if I’m wrong hereI do not believe it was always the same set of characters. Seems like I’ve seen a lot of transmission stamps with and S in the derivative, which is not typical of the engine derivative stamp. Were there two different gang holders and as a result two different sets of stamps?
Roy------
I believe that 2 stamp gang holders were used, but the stamping was done by the same person at the same station. Why 2 different gang holders were used I've never been able to figure out.In Appreciation of John Hinckley- Top
Trans formats were: '62 thru '64; 21xxxxx thru 41xxxxx
'65 was supposed to be S1xxxxx, but early cars still used the previous model year formats. I've seen VIN 5101372 with a large 'S' overstamped on the 5.
Then, in '66, they added back the model year in front of the S.
So must have been two gang holders, or they added/removed the S from the holder, depending on whether they were stamping the engine or trans.
Reports of a few '66 engine blocks being stamped that way (with the S) until they got used to the change.
- Top
Joe- From 61 to 67 the engine gang stamp holder held 7 characters, and the same vin derivative was used on the transmission and engine (except 65 when the "S" was substituted for the 5 on the transmission). But the 66 and 67 transmission codes with the added "S" required 8 characters. Therefore, a different holder would be required for those 2 years. The 1968 and later vin derivatives used the same 9 character codes so the same holder would be used on both trans and engine. Also the characters were smaller so that 9 new characters would now fit in the same holders previously used for the 7 character vin derivatives.- Top
Sure seems that it would be easier and faster to simply stamp the trans. the same as the engine and then pull a "S" out of your pocket and stamp over the 5. That's obviously what they did on mine.- Top
Your transmission and Wayne's are interesting examples of how they tried to fix the mistake of not taking the 5 out of the holder and substituting the S. Why they thought it was so importent to put to put the S in the vin derivative that they went to even more trouble in 66 and 67 is not obvious. There were no Federal requirements about parts marking before 1968.- Top
