Any1960 Fuel injection technicians in the San Antonio, Texas area? - NCRS Discussion Boards
  • George W.
    • May 31, 2000
    • 543
    Hoping someone knows of a qualified 1960 Fuel Injection technician in the San Antonio, Texas area.
    Thanks for any leads,
    George Wright
    210 748 4693
    geopar@gvtc.com
  • Don H.
    • December 1, 1981
    • 1482
    Re: Any1960 Fuel injection technicians in the San Antonio, Texas area?
    Have you checked with the Texas Chapter? I know they have some members that do work but I have no idea where they are. Don H.
    • Gary C.
      Administrator
      • October 1, 1982
      • 17549
      George,
      You might check with Dan Martin 210-422-5961
      Otherwise it's Gary Summerville south of Houston who would be the closest.
      Gary
      NCRS Texas Chapter
      https://www.ncrstexas.org/
      • George W.
        • May 31, 2000
        • 543
        Talked with Gary and and Dan. Gary thought it sounded like a distributor problem.
        I changed or distributors and viola, runs almost perfect.
        George
        • John D.
          • December 1, 1979
          • 5507
          More fuel injection complaints are in fact electrical as seen by George Wright's issue. Glad you found the problem George.
          • George W.
            • May 31, 2000
            • 543
            Couple photos and short video:
            Click on image below for video---First time owner has driven his Vette since 2004!
            Here's a couple shots of what we started with:
            What broght the Vette to the shop in the first place
            Car was White, He wanted Red; Here's some of the things found after stripping the paint:
            Making progress:
            "custom" paint booth exhaust system.
            • George W.
              • May 31, 2000
              • 543
              Wondering what happened to some of the photos and short movie?
              • Gary C.
                Administrator
                • October 1, 1982
                • 17549
                George,
                The Photobucket Owner, moved or deleted them or changed the link.
                NCRS TDB has absolutely no control over photos stored on another site.
                Gary
                NCRS Texas Chapter
                • John D.
                  • December 1, 1979
                  • 5507
                  Notice Georges first photo showing a really broken/destroyed black plastic nozzle block. Reason it broke is quite evident. The 1/4" bolt that holds the nozzzles and nozzles blocks on is really cranked down.
                  You should be able to slip a business card in between the cadmium plated H shaped nozzle retainer and the black plastic nozzle block. Don't worry about how many thousands of an inch clearance. Just be able to see daylight between the center of the nozzle block and the steel retainer.
                  When you take the nozzle block off the H shaped retainer is bowed. When you go to re-assemble turn the bow up like you were a carpenter working with bowed lumber.
                  Last of all don't over tighten the nozzle blocks as the brass bottoms of the block will break/split.
