Trying to determine why steady vacuum at idle is 12 when most suggest it should be between 15-19.
1) removed valve covers and re-checked lash--all good at 12 intake, 18 exhaust.
2) The heads are from a '62 (3795896), but have the same cc(59.669) and valve size(1.72/1.50) as the 1960 3774692. Wondering if the rocker arm ratio is different on these heads, and if so, maybe someone can identify these rockers (they have an "O")--see photo below. Don't know if a different ratio would have any effect on vacuum, but???
3) Re-checked compression--140 in all cylinders
4) Re-checked timing and dwell
5) Did find something with distributor. When I pulled the rotor, I saw that the advance weights were "under" the breaker cam. Upon investigation I found that the shaft and weight base could be push/pulled about 3/8" (did not measure--but it is a significant amount of play). When pulled up, the advance weights react to the breaker cam, but still a bit sloopy/loose in my opinion.
When pushed down, (as I found when pulling the rotor) the advance weights go right under the cam. Now I know this is not correct, but I do not know if this is related to either the vacuum and/or the performance of this FI unit?
Below is a movie (not a great one) that shows the relationship of the advance weights to the breaker cam while in both positions.
Thoughts?
George
210 748 4693
geopar@gvtc.com
Thoughts?
George
210 748 4693
geopar@gvtc.com
