Does anyone know where I can get an original cap for my 1972? Preferable in very good to excellent condition?
1972 gas tank cap
Re: 1972 gas tank cap
Jerry
Here is one the Bay.
- Top
Jerry-----
1972 used the GM #3994339 gas cap. This cap is still available from GM for a list price of about 45 bucks. If there are any differences from the original cap, I don't know what they are. However, it may be that the Stant Manufacturing logo is a bit different.In Appreciation of John Hinckley- Top
Paul/Joe, The local Chevy dealer can get one for me by tomorrow. I know the '72 has "OPEN SLOWLY CAUTION" and "SEALED" embossed into the topside of the cap and the sides are smooth vs scalloped.
What I am not sure of is the design of the original SMC logo. From memory - I think the eBay item has the correct original logo. Your thoughts.- Top
Jerry------
The current GM piece will almost certainly have the modern-day SMC logo. Otherwise, I believe it's identical to the original cap.In Appreciation of John Hinckley- Top
Jerry
As Joe stated the current will just have a large "S" only. The one on ebay has the original style the SM then a large "C" encircling the first 2 letters then it is all inside a full circle or ring for Stant Manufacturing Corporation if I recall correctly.- Top
I have seen the replacement caps they are shaped the same, but the plating in not silver Zinc as the one on E/bay , it is gold diachromate and the smc logo is different.Paul/Joe, The local Chevy dealer can get one for me by tomorrow. I know the '72 has "OPEN SLOWLY CAUTION" and "SEALED" embossed into the topside of the cap and the sides are smooth vs scalloped.
What I am not sure of is the design of the original SMC logo. From memory - I think the eBay item has the correct original logo. Your thoughts.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Edward------
The eBay cap has the dichromate (gold) over-plate. I don't know if the originals had this finish, or not. In any event, it's easy to remove. Just immerse the cap in a weak acid solution. This has to be done carefully, though, or one will blacken the underlying zinc plating.In Appreciation of John Hinckley- Top
