Question on 69 L-36 - NCRS Discussion Boards
Question on 69 L-36
  • Pete B.
    • February 22, 2007
    • 318
    Question on 69 L-36
    Hi,
    I'm away from my books and have a couple of quick questions...
    I'm looking at a 69 L36 427 390 hp... 4sp, air
    I'm trying to determine if its a real big block car...
    What is the tach red line? what else obviously pops out as a "born with" big block?
    Big stabilizer bars front rear, aluminum radiator, with correct rad support, of course the hood, bigger differential and half shafts?
    floor insulation...
    Not looked at pad yet...will be seeing later today...
    THANKS a bunch!!!
    Pete
    Pete Bergmann
    2005 - 2013 C6 National Teamleader
  • Jack C.
    • September 30, 1992
    • 1090
    Re: Question on 69 L-36
    5600 on the Redline
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
    • Dick W.
      • 10483
      Originally posted by Pete Bergmann (47041)
      Hi,
      floor insulation...
      THANKS a bunch!!!
      Pete
      Brass/copper radiator with 27 1/2 inch core
      Dick Whittington
      • Jim T.
        • March 1, 1993
        • 5351
        Does the owner have the 69's original warranty booklet with the metal plate still attached? The plate will have all the information to confirm the 69 427. It will also have the original owners name.
        • Pete B.
          • February 22, 2007
          • 318
          Thanks all for the replies...
          There is nothing from the owner...no POP. I will be looking at it first hand and wanted to be a little better informed.
          There may be a tank sticker but I wont be able to access it.
          Pete Bergmann
          • Larry E.
            • 1652
            Hi,
            floor insulation...
            THANKS a bunch!!!
            Pete
            Pete: Its a long shot but it worked for me. Check the title and some states have "taxable horsepower" on them with the formula to figure
            the cubic inches out. Larry
            Larry
            LT1 in a 1LE -- One of 134
              Larry -
              "Taxable Horsepower" = Bore squared x 8, divided by 2.5.
              327 & 350 = 51.2
              396 = 53.6
              427 = 57.8
