Any knows who( if any)sells U nuts/J nuts for fan housing 1964 factory AC - NCRS Discussion Boards
  • Claus S.
    • December 30, 2010
    • 414
    I am looking for U nuts and bolts that attach the fan housing to the outer AC assembly
    I tried to bend some evaporator clips but that was no success
    You can see what they look like on the pictures
    The clip shows best on the left picture
    Note that the clip is bent up inside the housing so it will have a good fit in the center for adjusting of the fan housing
    If nobody sells these clips and bolts is there any that have a good suggestion on what kind of clips i can use?
    Blower Motor inner housing J-clips other side of the picture.jpgBlower Motor inner housing screws.jpg
  • Gene M.
    • April 1, 1985
    • 4232
    Re: Any knows who( if any)sells U nuts/J nuts for fan housing 1964 factory AC
    For the U nuts try Tinnerman Corp. I think they were an original supplier to GM.
