Ok now that I know that these are rear bumpers, how can I tell if they are originals. Using a micrometer I get .102 to .109 for thickness.
66 Bumpers, original or repros?
- Top
Re: 66 Bumpers, original or repros?
Ok , here are some more pictures, hard to take pictures of chrome. I measured in six different places and came up with the following, .90,.92,.98,.94,.98,.95bumperb.JPGbumpera.JPGbumperd.JPG- Top
There have been more than one supplier than Paragon for the repro bumpers. I personally know of two more and think there are at least two-three more. Originally two different companies were sourcing them from the original GM tooling, one being of better quality because of the metal finishing work done after the cores were stamped. There have been at least one offshore manufacturer also. Thin bumpers make me think of offshore sourcingDick Whittington- Top
Paragon still uses the original GM draw dies, but the GM trim dies have deteriorated long past the point of being economically rebuilt; the GM trim dies have been replaced with a robotic laser-t r i m m i n g operation.
MidYrTrimmed800.JPG- Top
.10 is consistent to when they went to run these mid 80's, before Paragon got a hold of the tooling.
Looks like John's been to Livonia. BTW that laser trim will be what is noticable as well, you won't have the sheared jagged back edge.
But then again, nothing looked like the original, starting with running this with the original steel.- Top
The quote to rebuild the dies was well over $250k 20 years ago.Dick Whittington- Top
Yup -
I spent two days at QMC with Chet and Kerry back in 2008 photo-documenting every step of both the C1 and C2 bumper manufacturing, welding, metal-finishing, and plating processes for a feature article I wrote in "Corvette Enthusiast" magazine. With all the handwork involved, especially for the '58-'62's, it's amazing that they make a dime on those bumpers.- Top
Measurement of 3/32" is too thin to be original. The drawing process yields thickness thinner at the deeper draws and less effect on the flat edges. Should be around .110" to .120" depending on where you mic it. Of course the plating adds thickness of around .006" give or take. Take more often. Replaters do a heavy finish compared to GM of the 60's. A plating on the inside surfaces will measure thicker.- Top
