1958-1962 Front & Rear Emblem Foam-Rubber Seal (Gasket) - NCRS Discussion Boards
  • Justin B.
    • March 1, 1996
    • 478
    Are the foam seals supposed to hang out around the chrome bezel? I can easily see mine once the emblem is installed.
  • Cliff P.
    • January 18, 2008
    • 19
    Re: 1958-1962 Front & Rear Emblem Foam-Rubber Seal (Gasket)
    Believe you will find seal goes under body not on top
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11302
      Cliff is correct, the seal is between the body and the backing plate.
      • Philip P.
        • February 28, 2011
        • 558
        From the ST-12
        • Christopher R.
          • March 31, 1975
          • 1599
          The 1962 AIM indicates .025 oz of 466943 cement around the 3 bezel studs. Don't know what "466943 cement" is. But I'd guess it was "dumdum." Mine leaks there without the dumdum.
