Drive line grinding/vibration - NCRS Discussion Boards
  • Harold R.
    Infrequent User
    • December 20, 2010
    • 26
    57 fuelie under heavy acceleration there is a grinding/vibration noise. Only occurs with heavy acceleration. There is no evidence of anything rubbing or hitting anywhere. Would appreciate any ideas anyone may have.
    • 6940
    Re: Drive line grinding/vibration
    Harold have you looked the drive shaft U-joints? They will cause a driveline vibration under accel and make a grinding type noise when the internal needle type bearings inside the cups loose there lubrication, They will start to get chewed up in quick order.
    • Harold R.
      Infrequent User
      • December 20, 2010
      • 26
      I haven't looked at the U joints but that is an easy place to start. Thanks for the suggestion.
      • Mike M.
        • May 31, 1974
        • 8365
        if the u-joint's zerk fitting(or just the plateau cast for a zerk) was incorrectly installed so that the zerk fitting is in close proximity to the pinion shaft, it may be bottoming out on the pinion shaft under accelleration. the plateau should face towards the front of the car, not the differential. mike
        • Mike M.
          • May 31, 1974
          • 8365
          PS: if the u joint is contacting the pinion shaft, you'll see a dent in the shaft. mike
          • Paul J.
            • September 9, 2008
            • 2091
            Do you feel the vibration through the steering wheel or the seat? If it's through the steering wheel then it's your tie rod ends. If it's through the seat then it can be u-joints, an axle bearing, something in the rear end, or even a motor mount.
            Paul
            • Harold R.
              Infrequent User
              • December 20, 2010
              • 26
              replaced "U" joints and it solved the problem. Thanks for every ones comments
              • Mike M.
                • May 31, 1974
                • 8365
                was the zerk plateau bottoming out on the pinion shaft?mike
                • Paul J.
                  • September 9, 2008
                  • 2091
                  Harold,
                  U joints fail slowly. When they are so loose that the bearings are about to fall out, they will vibrate a lot at speed. However, when they just starting to fail they will squeak. If you roll the car slowly beside of a wall (preferably masonry) at 3-5 mph you can hear the noise. It will go "squeak squeak squeak..." rapidly.
                  Paul
                  • Harold R.
                    Infrequent User
                    • December 20, 2010
                    • 26
                    No the u joints had been installed incorrectly. The caps were not down inside the built in retainer and had backed off. the u joint shaft was actually bent.
