How to restore a STV valve? 1964 coupe with factory AC - NCRS Discussion Boards
  • Claus S.
    • December 30, 2010
    • 414
    Re: How to restore a STV valve? 1964 coupe with factory AC
    I had a friend come by this afternoon and he had with him a AC compressor he gave me for free
    He gave me a power steering kit(except the pump and brackets for the pump)for free as well
    I know this compressor is for a Corvette and by looking at the numbers is this compressor made in 1967?
    Do the AC compressor for a 1964 look just like this one?
    • Wayne M.
      • March 1, 1980
      • 6414
      Claus -- the cast date of the rear head is that between the two slot-head screw imprints. (I-16-2 ?) The meaning of the "D" casting is unknown, AFAIK. "302" is good. You'll need to flip it over to show us the top seam in the barrel and whether it is swaged or crimped to the front bracket; appears to be crimped ('66 or later ?) going by what is visible on the bottom view.
      The pulley diameter seems to be too small for a '64.
      • Bryan H.
        • August 31, 2004
        • 120
        #18
        if you decide to go to an outside shop. i used Vintage air to restore my 65 STV and muffler along with A/C Compressor etc. LICS is good for all the hoses..
        • Claus S.
          • December 30, 2010
          • 414
          #19
          Wayne. I thought the D was for the month the compressor was made and that 162 was the day and year
          Bryan. If the compressor is not right for my car i wonder if i will go for a lighter newer one if they work on R12?
          I do not want to remove the STV valve because i want it as much original looking as possible
          It look like the date code is 162 but it looks like there is a 1 or a Y or some number/letter before the number 162?
          Here is a enlarged picture of the number and some more numbers of the compressor
          Does the brackets for the compressor only fit original exhaust manifolds? Can they be used on a car with headers?
          Compressor 07.03.13. Bilde 3.jpgKompressor jeg fikk av Karl. Number 6555302. Date D27. Bilde 2.jpgCompressor bacskisde.jpg
          My friend that gave the parts have a 1973 convertible that the compressor might have been in when i bought the car
          • Claus S.
            • December 30, 2010
            • 414
            #20
            I tried to find any Corvette parts shop that have the correct clips and screws that attach the blower motor fan housing to the AC box but the clips and screws was almost impossible to find
            I do not think that any sells this clips because i have been searching all over the internet for them, but after a while i got the original clips and screws
            I put on the STV valve and the fan housing to the AC box just to make sure that everything fit nice(and i wanted to see the parts bolted together)
            I put the STV valve halves together so the absolute vacum regulator was placed inside the STV valve bracket which i think must be the correct way to put the valve together
            • Wayne M.
              • March 1, 1980
              • 6414
              #21
              Claus -- I still think that casting date on your back head is I-16-2 (Sept 16th 1962 - or '72, as you say, but I think they were using a 3550406 cast rear head with a superheat switch connection by then).
              Here's one I have dated Oct 13th 1963 (2nd pic). Notice the relief valve has a slot (not a hole) and is stamped 440#. Also, the pulley dia. is 5.75" which I think is correct for 1964 (I don't have the NCRS manuals for that MY). The clutch hub has the 6 holes, rather than the 3 rectangular openings around the shaft.
              • Claus S.
                • December 30, 2010
                • 414
                #22
                Wayne here is a better picture of my compressor
                • Claus S.
                  • December 30, 2010
                  • 414
                  #23
                  I finished the last bracket for the factory outer AC assembly today
                  I have been searching for the parts on the picture since i bought the car back in 1993 and all i have left to do is to put the AC assembly back on the car
                  It is a nice feeling that the outer AC assembly is ready to be put on the car since it have been the major parts to to try to get and the most important parts on my list of what to "do`s"
                  I made that bracket so it is not 100 precent like the original bracket but it will have to do until i get a original one
