1966 body shim orientation question. - NCRS Discussion Boards
  • Michael H.
    Infrequent User
    • March 1, 1990
    • 26
    I'm ready to place my 66 body back on the frame. When I was studying the assembly manual I noticed that the bent corners on the shims were placed pointed up, for body mount 1,2, and 3. Body mount 4 has the shim corners pointing down. Is this correct?
  • Gene M.
    • April 1, 1985
    • 4232
    Re: 1966 body shim orientation question.
    Mike,
    Convertible at firewall shims sit on top of alumunum puck with points down.
    Coupe at firewall shims sit on top of washer & cushion with points down.
    Convertible under rocker sill shims sit on top of frame hat section with points down.
    Convertible and Coupe in front of rear tire I can't remember....... I think points up, shim first with puck rubber on each side of birdcage.
    Convertible and Coupe behind rear tire shims sit on top of washer & cushion with points down.
    In all these cases a 1 1/2" wide tape holds the shims and cushions (aluminum puck) to the ears of the frame prior to body drop and remains in place.
    • Michael H.
      Infrequent User
      • March 1, 1990
      • 26
      Thanks Gene for your response. I should mention I have a convertible.
