Should I keep these bolts? - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2580
    These are some bolts I took of my 1960 during restoration. Are they GM/Corvette correct bolts or just hardware store bolts? I check the Joseph Tripoli "Chassis Restoration Guide" and didn't see any of these head marks. I've also search the forum, but didn't see anything like these. I know the is a Flacon Forge Inc bolt, which was I believe a GM supplier, but not sure about bolt originality.
    If they are correct for C1 vette then I will keep them.
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Gene M.
    • April 1, 1985
    • 4232
    Re: Should I keep these bolts?
    Don,
    I've seen the center one before, can't say the same for the other two.
    • Patrick S.
      • January 1, 1988
      • 209
      I have a couple of each in my "NON CORVETTE" box
      • Dennis C.
        • June 30, 2002
        • 884
        Don,
        Not typically what I would expect to see. Do you remember exactly what component they were from?
        Dennis
        • Dick W.
          • 10483
          The center one is an Anchor, used in C-2 and C-3 applications. Not sure about C-1. The left is Premier manufactured, the right I am not sure. Premier was not a OEM supplier
          Dick Whittington
          • Donald H.
            • November 2, 2009
            • 2580
            I'll stick them in a Non Corvette box for now.
            Don
            Don Harris
