Re: Half Shaft dab?
Mike, I am confronting the identical issue that you raised about how to restore the half-shafts and drive-shaft to their original finish and sheen. No one seems to think it can be done short of having the shafts "re-tubed." But like you, I am determined to try. I have found that sanding down deep enough to eliminate most of the pitting on a used shaft and then progressing up through finer grits of sandpaper results in the shafts becoming too shiny (and maybe also too smooth). Graeme suggested using Dioxidene... but I don't really know what that is and, in any event, I can't seem to find it. I thought of using another kind of readily available heavily diluted acid-based mixture, but I'm pretty sure that would simply etch the shafts--which I assume again would produce the wrong finish.
A friend of mine suggested blasting the polished shafts very lightly and from a distance using walnut shells as the medium. That's something I might try and simply wanted to share it with you. You mentioned scoring the shafts length-wise to replicate the extrusion marks, but if they were originally a flat piece of rolled metal, I assume they would not have such score marks? But both the half and drive shafts should have the longitudinal (lengthwise) seam, right?
One thing that confuses me somewhat is how the seams were originally welded length-wise. I have seen pictures posted here of an original shaft displaying about a quarter-inch wide longitudinal seam that is very straight and of even width. (It would be great if someone could post a good picture showing such a seam.) But there were no apparent grind marks around this smooth bluish-colored seam. Were they welded from the inside using some type of automated method, leaving just the welding burn marks on the outside? Is it better in the view of the experts here to replicate the weld marks on both the rolled ends and the longitudinal seam using a torch versus the "gun blue" chemical? If the torch method is more realistic, how could one replicate the very straight and constant-width longitudinal weld using a torch?
that was applied to trailing arms, etc., in that time frame.
