do I have a 427/435 housing? - NCRS Discussion Boards
  • William B.
    • April 30, 1975
    • 939
    427 dist 3.jpgAre the tag #s correct the 1st #1 is stamped very lightly? I found this in a box of parts I had from the 70's, wondering if with a different tag can I use this in a 66 427/425 which needs a housing like this for the rear cam bearing oiling?
  • Mike Z.
    • 226
    Re: do I have a 427/435 housing?
    Is there provision for a vac canister-can't tell from the pics? If so, then this is a correct early BB distributor housing, as used on the 427/435HP your tag indicates or a 66 427/425HP you want to use it in.
    Mike
    ReNu-A-Vette
    • William B.
      • April 30, 1975
      • 939
      please review, I have added a 3rd picture
        William------
        You could use this housing for your application. However, you do not have to use this style housing. You can use the type with the full-round oiling, too. That type SERVICED all 62-74 applications. No one would ever know what type was installed in your engine. However, since you have the original style, you might as well use it.
        • Mike Z.
          • 226
          Yes, the third picture confirms you have the correct housing for an early BB 65-67 427. Note: GM corrected/changed the block on the 396 in 67 and it no longer required the unique housing-it was not till 68 that the 427 was changed. The reason I asked to see the top, or at least ask about the vac canister provision is: the race intended #263 looks similar from the side (including the lower groove), but had ball bearing at the top and had no provision for a vac canister. The #263 unit would certainly work in your intended application, but would not pass judging, etc.
          Mike
          • William B.
            • April 30, 1975
            • 939
            thank you for all the information
