'67 Transmission tunnel insulation - NCRS Discussion Boards
  • Michael J.
    • January 27, 2009
    • 7073
    I am replacing the tattered, old insulation on the underside of the tranny tunnel, what glue works best here to glue the new piece in? Thanks for any tips.
  • Jim D.
    • 2882
    Re: '67 Transmission tunnel insulation
    I used a few globs of "Liquid Nails" along with the original clips. It worked great.
    • Michael G.
      • January 1, 1997
      • 1251
      If your clips are good no need for glue and the extra work.
      • Jim D.
        • 2882
        Glue was used in addition to the clips when it was installed at the factory. The top portion of the insulation will eventually sag down if some sort of adhesive is not used. The A.I.M specifies the use of 3 oz. of cement per car.
        • Gary S.
          Super Moderator
          • February 1, 1984
          • 456
          I like 3M 8088.
          Avatar--My first ever vette, owned 3X since 1977, restored 1993-2024. Top Flight Award 9/14/24
          • Michael J.
            • January 27, 2009
            • 7073
            Thanks all for the tips, and yes my "clips" are hardly there, had to get new ones but the original insulation obviously had glue in several places.
