I have a DeWitt 55M direct replacement radiator in my 1960. It is their aluminum reproduction of the copper radiator (Early 60 and earlier). It is not the later tank top radiator.
I bought a reproduction 7# AC cap, which leaks around the filler. Looks like I will use it only for judging. I know it isn't correct as an original, but I have assumed it will judge better than a auto supply replacement cap.
I am going to get an auto supply Stant cap to use for normal driving. I am ordered a GM cap that Joe Lucia recommended, but when I looked up the part number it says it is a 15# cap.
My question is, should I get a 7# cap or use the GM 15# cap? I assume with a 13# or 15# cap, the engine would get a lot hotter before it would release pressure. Other than that, is there any problem with running with a higher pressure cap?
DOn
DOn
