c2 door window regulator - NCRS Discussion Boards
  • Bob P.
    • March 5, 2007
    • 38
    I have a 65 that when cranking the main door window regulator causes the window crank to slightly hit the door panel when in the lower 1/3 rd of the turn. Someone had told me to take off the door panel and shim out the bottom portion of the regulator. Upon removing the door panel I can't see a way of shimming the regulator that would result in an angle change.
    Any Ideas?
