My 56 restoration project is almost complete and I am having an issue with my primary carburetor. It starts and idles great and revs fine when you pump the throttle. The problem is on gradual acceleration...it just acts like it is dying and has a huge pause in the accleration as you gradually ramp up the throttle. If you go quick, it jumps over it and seems fine. I originally thought the power valve spring was incorrect, then reworked the accelator pump. Those both appear to be fine, but I still have the problem. My car is ready to go except this last issue! metering rod issue? Power valve? Other adjustment?
Any suggestions?
Thanks, Mark
Any suggestions?
Thanks, Mark
