Need to paint 63 master cylinder. What is the correct paint to use?
C2 Master Cylinder Paint
Re: C2 Master Cylinder Paint
I painted mine on Monday. I used RUST-OLEUM BAR-B-Q-BLACK (7778). It's for high heat metal such as grills and stand alone wood stoves. The SKU number is 2066 77787.
Make sure the metal is absolutely clear of rust, grease, etc. You only need a thin coat and it will take up to 48 hours to set and dry completely.
It's been judged and no points deducted.
- Top
