Question on the operation of a Intake Manifold - NCRS Discussion Boards
  • Larry E.
    • 1652
    I see on Ebay and at Swap Meets Intake Manifolds for sale that the Oil Splash Shield(underneath of carb on back side of I/M)
    is missing. I know they did not put those on there for nothing but if a I/M was installed
    w/o the Splash Shield would the engine still run OK? How much of a difference does
    it make? Has anybody ever tried this? Thanks in Advance-Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Bill M.
    • April 1, 1977
    • 1386
    Re: Question on the operation of a Intake Manifold
    Here are the bottom of a '62 340 carbureted intake and the bottom of a '62 FI intake.
    The shield on the bottom of the carb intake is to shield the heat riser area from the oil.
    The FI intake doesn't have a heat riser, so no shield is necessary.
    Some OE carb intakes don't have the heat shield.
      Larry -
      LOTS of OEM aluminum intake manifolds don't have an oil splash shield. The shield isn't there to to keep oil from heating up the manifold - it's there to keep the oil from "coking" on the hot bottom surface of the exhaust crossover passage, and to contain any that does form there.
      • Stuart F.
        • August 31, 1996
        • 4676
        Thanks John for explaining that. The "heat riser" analogy was a new one on me.
        Stu Fox
        • Larry E.
          • 1652
          Larry -
          John:
          Thanks for the explaination; new one on me also. Larry
          Larry
            Stu Fox
            Stu -
            Virtually all 60's-70's OEM intake manifolds (except Rochester F.I. baseplates) have exhaust crossover passages that run below the floor of the plenum, from one side to the other; the flow of exhaust gases through them (to preheat the incoming air/fuel charge in a cold engine and improve atomization and cold driveability by minimizing "wetting-out" of the charge on the cold manifold walls) is controlled by the "heat riser" valve on the passenger side exhaust manifold.
            • Stuart F.
              • August 31, 1996
              • 4676
              I often wondered what they were for on the 40 or so I handled back in the day. Perhaps if I would have known that I could have bettered my "B" stock record by a few more tenths at Great Lakes Dragway (270 hp 57 Chevy post w/ 4-speed & 4.56 final; 13.27 et @ 106.4 mph w/street tires). Actually, I used FI intake gaskets w/the small oval holes, no heat riser valve w/ headers of course.
              Stu Fox
