58 paint code interior red ?? Help - NCRS Discussion Boards
  • Eric A.
    • December 21, 2012
    • 126
    I need some help getting the red interior Chevy color code. I have been searching with no luck. I am ready to paint but need this color code for matching otherwise I will have to start from scratch. Does anyone know that color / paint code.Thanks Eric
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 58 paint code interior red ?? Help
    Same as exterior color red.
    • Eric A.
      • December 21, 2012
      • 126
      Do you have that paint code .. Thanks Eric
      • Mike E.
        • June 24, 2012
        • 920
        Hope this helps.
        It's from here: http://www.tcpglobal.com/aclchip.asp...rolet-pg03.jpg
        Mike
        • Eric A.
          • December 21, 2012
          • 126
          This is a very large help thank you so much. Eric !
          • Wayne W.
            • April 30, 1982
            • 3605
            Probably will not do much good to have the code though. No modern paint formulations for it that I know of. You can try to call your supplier and ask if anyone has formulated it and has it on file somewhere. Sometime and individual has made up his own color and reported it to the paint company. Someone here may have approximated it. I see some correct looking Signet cars out there, but most are not. Auto Color Library may be able so supply it in lacquer.
            The first number listed on the chart, 506A is for solid colors, the second is two tone combinations.
