67' taking running gear off frame - NCRS Discussion Boards
  • Dave K.
    • January 24, 2013
    • 278
    Currently have body off frame and motor is removed. Is there any tension left in the front springs? Taking running gear off this weekend and I don't want to kill myself with a spring flying up.
  • Gary R.
    • April 1, 1989
    • 1796
    Re: 67' taking running gear off frame
    Yes still under tension front and rear. Be careful
    • Jim D.
      • 2882
      Yup, and by removing the body and engine (weight), the job of dis-assembly will be much harder as the frame will have to be anchored down in order to remove the tension from the springs.
      • Keith B.
        • March 7, 2008
        • 928
        Not unless you don't mind your lower a-arm flying down and hitting the floor with spring flowing it. It can be done just watch wear your hands and feet are at all times
        • William L.
          • December 1, 1988
          • 944
          Dave
          Here is a article I wrote for an easy way to do your rear spring http://stlouisncrs.org/news_files/St...r_Oct_2011.pdf look for "Relieving Tension".
          Bill
          Bill Lacy
          1998 Indy Pacecar
          • Dave K.
            • January 24, 2013
            • 278
            Thx for the info guys. I was going to work on it tomorrow by myself...but now it has me thinking???? Any ideas for the front springs?
            Dave
            • Timothy B.
              • April 30, 1983
              • 5177
              Dave,
              If you search the archives there are very good ideas regarding removal and installation of the front springs using a long threaded rod. Most of your questions will be answered because most of us have been through the same process.
              Safety first always.
              • Kenneth S.
                • July 31, 1981
                • 302
                For the front spring you really need to use one of these. Some auto parts stores rent them. Ken
                • Gary R.
                  • April 1, 1989
                  • 1796
                  The internal thread rod and plate will work the best. I made mine from Acme threaded rod to carry the load better.
                  • Scott M.
                    • January 1, 1996
                    • 216
                    Acme rod is of course the best but harder to find. Some 5/8" threaded rod and grade 8 nuts and washers work fine for the top, have to use a piece of angle or plate steel to span the lower hole in the bottom "A" arm, just use lots of grease on the rod. Insert through the top shock mounting hole and exit the bottom spring pocket.
                    • Gary R.
                      • April 1, 1989
                      • 1796
                      I used the common threaded rod as well, it lasted one removal before the threads rolled so that might be an option for a 1-2 shot deal. I bought the acme rod and nuts from McMaster-Carr cost about $30 for everything I think and I have used it several times works so much better.
                      • Dave K.
                        • January 24, 2013
                        • 278
                        Scott,
                        I'm not sure why you need a piece of plate steel to cover the hole in the bottom A arm. Don't you put the threaded rodthru the top shock mount hole and then thread the hooks onto the bottom portion of the rod so the hooks are hook on the spring near the bottom of the spring just above the bottom A arm? Then put the washers and nut on the top of th e rod and start tightening so the hooks that are at the bottom of the spring start to compress the spring up into the top A arm. Once the spring is compressed enough so the bottom of the spring is barely touching the bottom A arm then one can remove the bottom A arm. Once removed then loosen the nut so the spring can release back down. This is all new to me so pardon the ignorance if I'm looking at this completely wrong.
                        Dave
                        • Scott M.
                          • January 1, 1996
                          • 216
                          Dave, my reply and I assume Gary's is in regards to making your own compressor, if you use the store bought one as shown with the hooks that is a different story.
                          • Norris W.
                            • December 1, 1982
                            • 683
                            Originally posted by Dave Kocer (57952)
                            Scott,
                            Dave
                            You don't use the hooks. Just put a short piece of plate down there. I have mine done with two holes drilled for the shock lower bolt pattern so nothing moves around and then of course the larger center hole for the rod. It's also helpful to use the type of rachet and socket that's hollow so the rod can go all the way through it rather than having to use a wrench. One other way is to weld one of the nuts at one end of the rod so it can be turned with a rachet or air wrench and then hold the other end with a wrench. I've used old cheap hardware store threaded rod and grade 5 nuts for all these years and have never had one strip. Using plenty of grease on the threads seems to make the difference.
                              Here are a couple more variations of the rod-through-the-spring home-made compressor; simple and effective.
