Need Help With Removing Side Exhaust (Aftermarket)(1970-Big Block) - NCRS Discussion Boards
  • Monte M.
    • January 1, 1991
    • 687
    I need a little help from you guys that have either put on or taken off a set of 4 to 1 aftermarket side pipes.
    I have to remove a set of the 4 to 1 side pipes on a 1970 with a 454 in it.
    Can anyone tell me:
    1. How high did you have to get the car to get the pipes out?
    2. Did you have to raise the engine off the frame? (Unhook motor mounts)
    3. Is there anything else that I should know about attempting this?
    Any input any of you can offer would be appreciated.
