At what point in the factory assembly was the radiator installed and how?
I believe the radiator support was in place when the body was painted and blacked out (see Noland Adams book, pg 143, shows support installed in partially assembled body), but assume the radiator was not as it received no blackout. With the hood installed (as it would have been for paint) it appears it will not open far enough to allow the radiator to be slid into the support.
I've tried to install the radiator with the hood support installed and it doesn't come close, and it looks like the hood won't open enough further with the support disconnected before the hinges hit the body, but I haven't tried that yet.
Will I have to remove the hood to install the radiator?
Thanks in advance for your help.
