Simple question (I hope). My 68 427 has been sitting for 5 years. No storage prep was done before being parked. I have rolled the motor over by hand and have done the basics for the engine start, topped fluids, installed rebuilt carb primed the motor with oil pump primer tool. I am to the point of rolling it over using the battery (coil disconnected). So now what to do with the half tank of old fuel. I know I should drain it and start with fresh, but I have no way to get rid of the old fuel. So the question is. How dangerous would it be just to try to start with the old fuel?
C3 starting after 5 years
Re: C3 starting after 5 years
Paul- Top
Two weeks ago I woke up my '57 fuelie which, like your car, had been sitting for 5+ years with no special prep. I put gas in the bowl, verified the special FI gear pump wasn't locked up, and turned the key. That's ALL I did. Engine fired right up and ran well on the old fuel.
Don't over think this.
Jim- Top
You should be able to tell if the fuel is bad by the smell of it . Take offthe cap and take a wiff , stale gas has a smell you will never forget .
If it is stale smelling I would get rid of it before I cranked that stuff into the carb . Start with a new filter or better yet plumb an inline filter in that is easy to change and change it often for a while .
5 yr old gas is way too old ,
Bill- Top
A followup to my earlier post (#6) in this thread:
Today, I started our '59 283/230 which had been sitting for a year and a half. The fuel in the tank, according to the log, is three year old summer blend.
My procedure was this:
1. Get in
2. Turn key to START
The starter spun for between 10 - 15 seconds. Just as oil pressure began to show on the gauge, the engine started and remained running. I didn't prime the carburetor. I didn't even pump the accelerator.
FYI.....
Jim- Top
Simple question (I hope). My 68 427 has been sitting for 5 years. No storage prep was done before being parked. I have rolled the motor over by hand and have done the basics for the engine start, topped fluids, installed rebuilt carb primed the motor with oil pump primer tool. I am to the point of rolling it over using the battery (coil disconnected). So now what to do with the half tank of old fuel. I know I should drain it and start with fresh, but I have no way to get rid of the old fuel. So the question is. How dangerous would it be just to try to start with the old fuel?- Top
- Top
