I replaced all of the wiring harnesses in my 65.Everyting works fine except for the rear harness.When I turn on the lights, three of the four rear lights are bright as if the brake was being pushed, the fourth light is on but dimmer.When I push the brake pedal, the lights stay the same.when I turn on the right signal,I get both signal lights on the dash flashing but not on rear.Turning the signal left gets no flash just the right indicator on the dash on solid.The tail lights are also new and the grounda are clean and tight.Could it be a bad harness? All help will be welcome,right now I'm looking for solutions.
