Test stand starting, I need a flywheel - NCRS Discussion Boards
  • Robert K.
    • July 31, 1984
    • 213
    I have a rebuilt engine on a stand and would like to run the cam in on a test stand, but don't have a flywheel to start it. What CHEAP flywheel can I use to start this thing. Does it go by tooth count? or diameter? Will an automatic flexplate work? What years should I be looking for?
    Re: Test stand starting, I need a flywheel
    Robert -
    Assuming you're talking about an original manual transmission setup, you need a 14" diameter 168-tooth flywheel and C1 bellhousing (the starter bolts to the bellhousing on a C1, not to the engine, and only engages the 168-tooth flywheel).
    • Robert K.
      • July 31, 1984
      • 213
      What years and models can I find 168 tooth fltwheels? Will all 168 tooth flywheels work?
      • Bob R.
        • June 30, 2002
        • 1595
        The c-1 and c-2's had 153 tooth flywheels. You could use either size as long as the bellhousing and starter are correct for the flywheel.
          Bob------
          C1's used a 14", 168 tooth flywheel.
          • Bob R.
            • June 30, 2002
            • 1595
            My error
            As long as the flywheel, bellhousing and starter are the same size it should work.
            • Robert K.
              • July 31, 1984
              • 213
              Any 168 tooth flywheel should work with the stock bellhousing and starter?
                Yes, as long as it's for a 2-piece rear seal crankshaft (pre-'86).
                • Frank C.
                  • August 31, 2003
                  • 170
                  Check your inbox. I sent you a PM. If you are near me, I can loan you one I have extra.
                  Frank
                  Frank Clark
                  U.S. Army Retired, current serving DoD Civilian
                  C1 1962 300hp, 4spd. Black/Fawn
                  C2 1966 Coupe, L79, A01, C60, J50, M21, N40. Silver/Black
                  C20 1966 Custom Camper, L30, J70, M49, N40, G60, Saddle/White
                  C20 1966 Custom Camper, L30, M49, N40, G60, Saddle/White
