Or anyone with knowledge about the chassis buildup. This stems from Carlo's question on the front sway bar and the tag. As I state there, I have looked at a lot of chassis and low-mileage ones but have yet to see a front sway bar tag, either its color, abbreviated broadcast code or the part number. I can only conjecture that it probably was like the front coil springs. I know from buildsheets that it called out the last three digits of the part number. I would expect that any broadcast code would have the 318 (base) or 596 (FE7 bar). All I have ever seen is what appears to have been a tag that was either discolored by age or painted. Regardless, its not judged.
So my curiosity is what do you look for or have found regarding tags for either restored early C3s or original C3s?
added on the judging score sheet. We/I have seen them on unrestored cars but do not know for sure what color and what was printed on the label. We may never find out for sure but a person that has restored their car and add the label is just adding a higher degree of originality. The label being there or not in my opinion would change the scoring of the sway bar assembly as a whole. But it is always nice to see a owner go to that degree of craftsmanship and in most cases it will show across the rest of the car.
